Tamiya TA08R 详情
23-9-28 19:02| 发布者: rcfans| 查看: 3270| 评论: 2
Tamiya田宫模型公布TA08R电动房车详情,标配了大量原厂升级件。采用2.0mm厚度的碳纤二楼板,加入了强化骨架,减少碰撞后的损坏几率,提高完赛率。铝制前后悬挂臂码和铝制马达座,尾部新设计的可调高度车壳柱系统加入了碳纤压板和铝制车壳柱,减少车壳安装后的晃动,提升车尾的抓地力和稳定性。传动系统方面,前直轴和后齿轮差速以及产品编号42351已经用在TRF420的中置皮带轮也作为TA08R的标准配置,轻量化万向传动轴,铝制轮圈接合器,超短身大容量避震器也出现在这台战斗力更强的新车上。产品编号47498。
原厂升级件包括
• 51565: TRF419 Gear Differential Unit Aluminum Diff Joint (2pcs.)
• 22004: TA08 Aluminum Servo Mount
• 22005: TA08 Carbon Damper Stays (Front & Rear)
• 22016: TA08 Low Friction King Pin Balls (4pcs.)
• 42319: Lightweight Cross Joints for Double Cardan Joint Shafts (4pcs.)
• 42320: Lightweight Joint Casings for Double Cardan Joint Shafts (2pcs.)
• 42346: TRF420 Wheel Axles (2pcs.)
• 42351: TRF420 Center Pulley
• 42357: Cross Joints for Low Friction Assembly Universal Shafts
• 42359: VG O-Rings for Oil Dampers (30°)
• 42361: 43mm Drive Shafts for Low Friction Double Cardan Joint Shafts (2pcs.)
• 42363: Axle Shafts for TRF420 Double Cardan Joint Shafts (2pcs.)
• 42374: VG O-Rings for Gear Differentials (40°)
• 53823: Clamp Type Aluminum Wheel Hub (5mm Thick)
• 53968: 5x5mm Hard Hex Head Ball Head Connector (5pcs.)
• 53969: 5x8mm Hard Hex Head Ball Head Connector (5pcs.)
• 54121: Aluminum Horn for High Torque Servo Saver
• 54642: 4mm Flange Lock Nut (Black, 8pcs.)
• 51647: TRF420 Aluminum Front Direct Cups (2pcs.)
• 54704: TA07 Aluminum Steering Arm Set
• 54881: Aluminum Adjustable Suspension Mount (A)
• 54883: Aluminum Adjustable Separate Suspension Mounts (XB)
• 54884: Aluminum Adjustable Separate Suspension Mounts (A)
• 54949: TA07 Adjustable Ackerman Set
• 1/10 scale R/C touring car chassis kit.
选购Tamiya产品请进入
    引用 丘丘tt02cc01 23-10-3 22:46
    Pro版玩家暴怒
    引用 人穷车慢 23-9-29 11:42
