几天前Tamiya田宫模型预告了XV-02RS Pro,偏向"公路"行走的新款RS型号,今天这款新车的产品照片公布。产品编号58726,上市日期待定。
– Features oil shocks with aluminium cylinders employing shaft length suitable for road performance and dedicated 3.5mm thick carbon fibre shock mounts and carbon fibre reinforced rigid lower deck. – The 18-spoke wheels are matched with semi-slick racing tyres. – Front mid-mounted engine plus long front and rear drive shafts of identical length. – Comes with two 39T differential gears and one 40T differential gear for front and rear drive adjustment. – Use 39-tooth gears (with 15-tooth gears) at the front and rear for standard transmission balancing, 39-tooth gears (with 15-tooth gears) at the front and 40T gear (with 15T gear) at the rear for forward transmission balancing, and vice versa for rearward transmission tilt balancing. *Use the latter two with slipper clutch and centre differential. – The longitudinal battery pack is positioned to the centre left for optimal balance. – The flat bottom of the chassis and the slip angle on the front bumper further contribute to limiting surface contact. – The caster blocks feature a six-degree angle. – Includes universal drive shafts front and rear and an aluminium servo mount. – Please note that a polycarbonate chassis cover is not included in this version.
选购Tamiya产品请进入 |
