CEN MG16TC Q版房车
07-8-6 09:24| 发布者: admin| 查看: 3568| 评论: 0
CEN的MG16系列又有新品种了,这次是一款样子趣怪的房车M16TC。虽说是TC,其实车架还是越野的结构,配上2.5cc的引擎,很适合在各种场地玩。
CEN Racing is proud to introduce an all new one of a kind, purpose built mini nitro touring car. The MG 16 TC has much more than speed, durability, and great handling, it has character. The MG 16 TC was designed for hobby enthusiasts of all ages and skill levels. The MG 16 TC does not discriminate when it comes to having fun. Driving the MG 16 TC brings endless hours of fun and excitement. Experience the one of a kind nitro touring car that offers more nitro and more fun than any other mini nitro TC car in the market!
Full time shaft driven 4wd makes the MG 16 TC handle like a dream while backed up with a powerful 2.5cc nitro powered motor that screams down the straightaway and powers out of turns. Burn some rubber with the touch of your fingertip! The MG 16 TC is fully (RTR) Ready To Rock and includes the fully digital and highly advanced Skyion radio system. Whether you’re on the track or in your neighborhood the MG 16 TC will meet and exceed your demands, compared to any other mini nitro touring car in the world!
H.I.C. by CEN Racing
CEN Racing is always striving to think outside of the box to bring hobby enthusiast the very best product available. We understand what the hobbyist seeks and expects in a product because we too are hobby enthusiasts. Our latest development is our state of the art H.I.C. or High Impact Composite. This composite has been proven and tested to be the most durable composite of its kind. After months of testing our engineers and research and development department have constructed the H.I.C. material that is exclusively available with the MG series vehicles. The composite is extremely flexible which will give upon impact. Not only does the H.I.C. material work effectively in that is doesn’t snap or break, but it give the vehicle tons of traction and stability as well. We understand what the most important aspects to bashing, and jumping your r/c vehicles are, having fun and driving them. With the new H.I.C. material you will experience more driving time which will lead to more fun which is what the hobby is all about!
  • Completely Ready to Run
  • Skyion DSX Radio System
  • Lighting fast Acceleration
  • Full time shaft driven 4WD
  • High flow manifold with rear exit exhaust
  • Powerful 2.5 Engine
  • Reinforced composite chassis components
  • Ball bearing supported
  • 75cc fuel tank with filter
  • Built in servo saver
  • Sealed receiver and battery Compartment
  • Single Speed Transmission with Slipper Clutch
  • Big Bore Oil Filled Shocks
  • Adjustable toe-in and camber
  • Adjustable Suspension geometry
  • Stylish 2.2" offroad wheels
  • High Impact front bumper
  • Compatible with 1/10 parts, Unlimited upgrade potential!!
1. The MG16 is full time shaft driven 4WD with unique bevel gear differential design.  Notice the unique molded chassis, the center cutout allows for the drive shaft to at the same level as the chassis itself, this allows for the MG16 to have a lower overall CG for enhanced handling prowess.
2. High Performance Oil Filled Shocks - Adjustable oil filled coil over shocks providing the best on track performance with unlimited adjustability
3. Sealed battery compartment located at the bottom of the chassis. This allows for the MG16 to have a lower overall CG for enhanced handling prowess.
4. Equipped with 75cc fuel tank and lightweight chassis, the MG10 provides over ten minutes of tire shredding fun on a tank of nitro.  Less refueling and more Driving
5. High Impact Foam Bumper server as a buffer zone and reduce damage under collision.
6. The MG61 with its .stump pulling 2.5cc pull start engine gives the MG10 blistering acceleration. Don’t be afraid that the power of the MG16 will just lead to you spinning your wheels, with the full time 4WD you won’t find yourself short of grip to get the power to the ground.
7. Using resilient composites instead of aluminum, the MG16 combines lightweight with rugged durability.
8. Knowing that the MG16 will see action in the dirt and mud, CEN SPORT designed the MG16 with a fully sealed radio box.  Keeping your electronics safe and sound is critical to having Nitro RC fun day in day out
