活动时间:2019年6月21日-22日(北美时间) 地点:Warsaw Caves Conservation Area and Campground 289 Caves RD. Pesterborough 安大略省 加拿大 报名费用: 小孩15以下免费 成人 $45 TTC (泥地拖车挑战)and TerraCross and Night Stage (夜爬)“Hat Trick” 额外 $10 (价格均为加币) 报名方式:Facebook(脸书)搜索 Recon G6 里面有Post世界各地活动时间,活动地点,活动行程安排,报名链接,均可网上直接报名 见下图 本次活动时间安排(总共两天时间): 第一天: -10:00am-12pm - Driver Check in/registration.(参加活动司机签到,领取各种小纪念品) - 12:00am – Drivers Meeting / TTC Start.(泥地挑战开会介绍) - 4:00pm – TerraCross track open for practice.(泥地挑战练习) - 4:30pm – Drivers Meeting / Heat Races Start.(司机集中开会,热身赛) - 8:00pm – Drivers Meeting / G6 Night Stage “Hat Trick" Start (夜爬活动开始) 第二天: - 9:45am – Canadian Anthem / Drivers Meeting / G6 Stages Open (司机集中开会介绍规则,回顾晚年活动,简单认识介绍) -10:00am – RC4WD Float Your Rig Challenge (攀爬挑战赛正式开始) -12:00pm – Driver / Driving Challenges Open (还是挑战赛) - 4:00pm – G6 Stages Closed / Turn in Driver Log Book to G Central (活动结束,交会比赛纪录小本、每个司机比赛过程人手一本记录比赛过程) - 5:00pm – Awards / Raffle (颁奖仪式,晚餐的聚会) 比赛组别: 1) Leaf Spring Class (悬挂为小扁担组别) -Hard Body only(必须为硬壳) -Scale tires only 2)Open Class - Hard Body or Lexan(开放组别,软壳,硬壳不限) -Tire height not to exceed 4.75 inches as marked from the manufacturer (轮胎不能超过4.75) -Must be scale tires -All vehicles must have an interior with a driver(必须带内饰和司机) -Stock frame rails -Truggy’s are legal, provided the front stock chassis is used -No rear steer(不允许后轮转向) -No dig(不允许使用段传) - Mandatory scale items: First Aid Kit. Fire Extinguisher. Tow strap 3) Extreme Class - Hard body or Lexan(极限组) -Tire Height not to exceed 5.4 inches as indicated on the side wall from the manufacturer (轮胎不能超过5.4) -All vehicles must have an interior with a driver -6x6 is permitted(可以使用6x6) -Frame can be C channel or Cheater Chassis / Flat plate chassis is permitted UTF Class - any lexan or hard body truck. Tire size cannot exceed 5.4in. Wheel size cannot exceed 1.9. Can be leaf or linked. No interior is required. 比赛规则(比较长 大致中文翻译一下): 大部分靠自觉遵守,其实更多的是,享受比赛过程,和乐趣 在赛道上出现任何故障,你都可以在时间允许的情况下继续前进或完成赛道,或停止跑步。 只要时间允许,你可以在挑战之间进行修复。 -你只能修理坏了的东西。 -不更换车轮轮胎,以不同的挑战。 -没有更换卡车的不同挑战。 3 s电池最大。 如果时间允许,你可以在每次挑战后清洗你的卡车。 (最重要一条,手不要碰车,最大限度保持仿真乐趣,翻车时候,必须等待队友救援,可以用胶盘,拖车钩) CLASSES: -Kids mini me“ (0-6) -Kids we cool“ (7-10) -Kids big dog“ (11-15) -Driving Divas -Seniors (56+) -R.A.D. Class (wheelchair and handi-capable drivers (must inform RG6 1 week prior to event per pm!!!) 420 Adventurers (16-39yrs, tires up to 4,2 in /107mm) 470 Adventurers (16-39yrs, tires up to 4,7 in /120mm) 550 Adventurers (16-39yrs, tires up to 5,5 in /140mm) 420 Veterans (40-55yrs, tires up to 4,2 in /107mm) 470 Veterans (40-55yrs, tires up to 4,7 in /120mm) 550 Veterans (40-55yrs, tires up to 5,5 in /140mm) 这些规则大致介绍分享一下,不一一列举了…… 本次我和朋友5部车子参加活动分别是 1: Axial UMG 10 2: Traxxas T4 PL FJ40 车壳 3: Axial Scx VP门桥 PL半卡车壳 4:Axial PL道奇皮卡 5: 还Axial Scx原厂RTR车架 PL半卡车壳 |
