VBC Racing 推出 WildfireD06 Dynamics 版本电动房车。基于标准的D06车架研发,加入了一些性能和耐用度提升组件,包括2.0mm 7075铝制底板、钛合金涂层避震轴心、悬挂摇臂轴、前后防倾杆等。
避震器加入了包括4孔活塞、绿点和白点弹簧等。 点击这里->进入VBC品牌专区参与互动
包括以下组件:
B-02-VBC-3043 WildFireD06 ALU7075 Chassis (2.0mm) NEW!!! A-01-VBC-0029 Graphite Bumper Top Plate B-02-VBC-0096 Titanium Coated Upright Shaft B-02-VBC-0098 Titanium Coated Suspension Arm Pin A-03-VBC-0077 Shaft End Shoe (Self Lubricating) B-02-VBC-3031 Titanium Coated Shock Shaft for TBB Shocks D-05-VBC-0095 TBB Oil Sealer Cap Set A-03-VBC-0138 TBB Shock Piston (4 holes) B-02-VBC-0136 TBB Shock Spring (Green-Soft) B-02-VBC-0137 TBB Shock Spring (White-Hard) D-05-VBC-0045 WildFire Front Stabilizer Set D-05-VBC-0046 WildFire Rear Stabilizer Set D-05-VBC-0032 WildFire Front/Rear Suspenion Shim (0.5mm) D-05-VBC-0033 WildFire Center Suspension Shim (0.5mm) D-05-VBC-0066 Center Suspension Mount (X/Y-C10) B-02-VBC-0061-20 E20 Suspension Mount |
