Discuz! Database Error
(1062) Duplicate entry 'portal/view_185-./template/rcfansdx-1923' for key 'PRIMARY'
INSERT INTO common_template_block (targettplname, tpldirectory, bid) VALUES ('portal/view_185','./template/rcfansdx', '1923'),('portal/view_185','./template/rcfansdx', '2245'),('portal/view_185','./template/rcfansdx', '2244'),('portal/view_185','./template/rcfansdx', '2238'),('portal/view_185','./template/rcfansdx', '2239'),('portal/view_185','./template/rcfansdx', '2240'),('portal/view_185','./template/rcfansdx', '2242'),('portal/view_185','./template/rcfansdx', '2243'),('portal/view_185','./template/rcfansdx', '2241')
PHP Debug
No.FileLineCode
1portal.php32require_once(%s)
2source/module/portal/portal_view.php278template(%s, %s, %s, %s, %s)
3source/function/function_core.php650checktplrefresh(%s, %s, false, %s, %s, %s, %s)
4source/function/function_core.php511update_template_block(%s, %s, Array)
5source/function/function_block.php1112table_common_template_block->insert_batch(%s, %s, Array)
6source/class/table/table_common_template_block.php65discuz_database::query(%s)
7source/class/discuz/discuz_database.php139db_driver_mysqli->query(%s, false, false)
8source/class/db/db_driver_mysqli.php148db_driver_mysqli->halt(%s, %d, %s)
9source/class/db/db_driver_mysqli.php223break()
rcfans.com 已经将此出错信息详细记录, 由此给您带来的访问不便我们深感歉意.
