发表于 17-7-25 21:39:43 |显示全部楼层
TRAXXAS技术贴视频第十二期---如何磨合滑动离合器
视频原创发布者 BY TRAXXAS
翻译者               BY TRAXXAS中国总代理电波模型
因涉及到模型专业术语,如若翻译有误,欢迎指正!
以英文原档为准,请参考:
TRAXXAS –How to Break In the Slipper Clutch | Traxxas E-Revo and E-Maxx Brushless
Brushless E-Revo E-Maxx models require a break in procedure on the slipper clutch to ensure consistent operation.
Slipper Clutch Assembly (Gear cover removed)
Follow these steps to ensure maximum performance and life from your slipper clutch.
Make your first few runs using the stock gearing and six or seven nickel metal hydride packs, or 2 cell lipo packs.
TRAXXAS 3-cell Lipo packs can be used if throttle is applied conservatively
Drive normal, the slipper clutch should slip momentarily when accelerating aggressively on high traction services.
Listen for a whirring sound in the slipper clutch allows the spur gear to slip.
When the clutch is cool, test drive the vehicle again.
If you experience excessive slippage, allow the slipper clutch to cool once more.
After the model has cooled off, turn the nut clockwise one quarter turn to tighten the slipper.
Continue to run the vehicle and monitor slipper clutch performance and readjust as necessary.
When the run is complete, the slipper should be fully broken in.
After break in is complete, the slipper clutch is ready for any type of driving.
With up to 6S Lipo batteries, the optimal setting for the slipper clutch will allow it to slip only momentarily.
If at all under hard acceleration and high traction conditions, always stop driving immediately if you notice excessive slippage and allow the model to cool before making any more adjustments.
请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新!
如果您想了解更多关于我们品牌的资讯,
请咨询电波模型淘宝店旺旺客服:
http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE
微信扫一扫,可得知最新资讯!
或联系我们
QQ  :2713236907/270570161
手机:13790546054  王小姐
