手机APP 微博 家园 视频 关于我们 Facebook Twitter
Traxxas 特约厂商 The Fastest Name in RC Rank: 21Rank: 21Rank: 21 发消息
帖子
856
注册时间
05-9-24
发表于 17-5-12 19:23:48 |显示全部楼层
TRAXXAS技术贴视频第五期---LaTrax 如何更换电机
视频原创发布者BY TRAXXAS
翻译者BY TRAXXAS中国总代理电波模型
以下是中国TRAXXAS总代理电波模型帮做出的翻译视频,
因涉及到模型专业术语,如若翻译有误,欢迎指正!
以英文原档为准,请参考:
LaTrax – How To Replace a Motor
Today we will show you how to replace a motor on your LaTrax vehicle.
Get a replacement motor for your vehicle and follow these steps.
You will need a small Phillips head screwdriver and a 1.5 millimeter hex tool.
And tools are recommended the power tools are fine when use with a low torque setting.
Remove the body from the vehicle.
Remove the four screws behind the speed control.
Note that the screws are different sizes and remember where they go.
Gently lift up on the upper chassis but do not pull directly on the electronic speed controls or wires.
This will allow you to slide off the gear cover.
Now remove the motor.
Use the 1.5 millimeter hex tool to remove the pinion gear.
Now remove the motor plate.
Remove the old motor and discard.
Take your new motor and attach the motor plate and pinion gear.
Note the orientation of the motor plate and the gear mesh spacer.
This spacer creates a perfect gear mesh when properly installed.
See that the gears is flushed at the end of the motor shaft.
The set screws should hit the flat spot on the motor shaft.
Connect the red wire on the motor to the red wire on the speed control.
Now connect the black wire.
Lift up gently on the upper chassis again to install the new motor.
The motor plate will slide into the grooves in the chassis.
Now replace the motor cover.
Reinstall the hardware you removed earlier.
Now your LaTrax vehicle is ready to go !
请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新!
如果您想了解更多关于我们品牌的资讯,
请咨询电波模型淘宝店旺旺客服:
http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE
微信扫一扫,可得知最新资讯!
或联系我们
QQ  :2713236907/270570161
手机:13712111381 王小姐
广告投放|联系我们|手机|投稿|导航|Archiver|About us|Advertise|遥控迷模型网|RCFans ( 粤ICP备10210518号-1
回顶部
