VBC RC 新手 发消息
发表于 13-10-11 09:29:05 |显示全部楼层
发表 D06 皮带驱动1/10四驱电房
The WildFireD06 is an all new platform, designed to increase traction, improve flex points, improve weight distribution, and center of gravity.
1. All-new motor mount design, moving the motor more centerline and forward increasing corner speed and overall agility of the car. Making this the most centerline touring car on the market.
2. All-new motor mount can incorporate a wider range of gear ratios from 21.5 up to modified classes
3. All-new chassis and upper deck providing more linear flex response and better weight balance
4. All-new redesigned front and rear A-arms to be much stronger but still lightweight
5. All-new roll bar mount for smoother response and easier adjustments
6. All-new 4mm thick lowered graphite shock towers improving CG
7. All-newly designed 'True Big Bore' shocks (TBB). Shorter shock shafts, bigger shock body diameter keeping the volume the same as original shocks
8. All-new TBB springs with 4 different rates (optional)
9. All-new redesigned lower bulkheads which are lighter in weight and stronger in durability by using our new manufacturing process
10. All-new upper camber link position for more linear cornering response
11. All new 7075 aluminium ball connectors
12. Front 2-piece joint drive axles included
13. All-new lightweight 7075 aluminium centerline servo mount included
14. High quality Panaracer 116T spur gear included
The Wildfire D06 has been designed to accommodate all standard 1/10 scale electronics
The all-new redesigned anti roll bar mount allows precise centering of the anti roll bar, as well as ...
The layshaft has been redesigned and is no longer affixed to the upper deck. This floating design a ...
A floating servo mount is affixed directly at the chassis centerline to improve the flex symmetry of ...
The 4mm quasi weave carbon fiber shock towers have been designed to withstand most any impact while ...
WildFireD06 Front Lower Bulkhead
WildFire D06 Rear Lower Bulkhead
WildFireD06 Motor Mount
WildFireD06 Motor Mount Support
WildFire D06 Motor Mount and Main Gear Bulkhead
Front Upper Bulkheads
