疯子 论坛元老 发消息
发表于 13-8-16 19:15:37 |显示全部楼层 来自: 中国广西南宁
Tekno RC’s presence in the 1/8th E-buggy class has been steadily growing since the release of the EB48 in August of 2012. Now they are introducing an updated EB48.2 buggy that is not only more competitive, but also represents the best value in the marketplace. Tekno RC has improved performance and durability without increasing the price of the kit. The list of improvements on the EB48.2 starts with their XT suspension arms as standard equipment which improves durability tremendously. They have included the +1.5 degree rear toe plate along with a new 0.5 degree offset insert to go along with the 1.0 and 0.0 offset inserts. New shock cartridges and shock bushings improve handling consistency and reduce shaft deflection.
The differentials have been overhauled with new cross-pins and internal gears as well as new straight cut CNC diff ring and pinion gears. The new gears are quieter, smoother and more efficient than previous gears and feature lightweight cutouts to reduce rotating mass. Lightened differential outdrives are used throughout. The lightened aluminum center driveshaft is now standard as well. A lighter drivetrain results in faster acceleration, higher top speed, and reduced wear. Their new angled rear gearbox and larger bearings round out the driveline improvements. The new gearbox reduces wear and increases efficiency by minimizing the drive angles.
Up front the EB48.2 features a new HD servo saver spring which helps to keep you pointing in the right direction. Lightened steering posts as well as lightened suspension sleeves help reduce weight without any sacrifice in durability. Aluminum hard anodized pivot balls are used throughout to reduce weight. A more durable servo horn has also been included.
EB48.2 New Features List:
Updated XT arms front and rear (TKR5030XT, TKR5036XT)
+1.5 degree rear outer toe plate for more adjustability (TKR5013B)
New differential ring and pinion gears for smoother and quieter operation (TKR5151, TKR5152)
Updated internal differential gears with low wear cross-pin design (TKR5149, TKR5150)
Updated shock cartridge internals to minimize shaft deflection (TKR6008)
Updated upper shock mount bushings to increase consistency (TKR6008)
Updated rear inner bulkhead with larger bearing to reduce wear and increase efficiency (TKR5016B, TKRBB05134)
Hard anodized aluminum pivot balls throughout – reduces weight (TKR5049A, TKR5052A, TKR5053A, TKR5058A, TKR5079A)
Hard anodized aluminum front spindle and suspension bushings – reduces weight (TKR5054A, TKR5055A)
Aluminum steering posts – reduces weight (TKR5102A)
Aluminum front center driveshaft – reduces rotating mass (TKR5077)
Lightened differential outdrives throughout – reduces rotating mass (TKR5112X, TKR5114X)
Updated servo saver spring for more precise steering feel (TKR5101X)
Updated steering servo horn for better durability
1.0, 0.5, and 0.0mm offset hinge pin inserts for more adjustability (TKR5021)
Updated setup sheet for improved handling
发表于 13-8-16 19:24:53 |显示全部楼层 来自: 中国天津
只要这个不再断臂,必入。
bassas  有时候在控制成本的前提下,够用就好。太贵了就走不出量了  发表于 13-8-16 20:19
ferrarifan  HSP的车也参加过比赛,也没断的,我们想要的,不是“刚刚够用”  发表于 13-8-16 20:14
疯子  之前JOHO兄用eb48比赛,也没见断  发表于 13-8-16 20:11
发表于 13-8-16 19:26:24 |显示全部楼层 来自: 中国天津
只要这个不再断臂,必入。
TIGER9901 金牌 Fans 发消息
发表于 13-8-16 19:31:53 |显示全部楼层 来自: 中国北京
居然是塑料大齿的中差。
Kenlcok  是尼龙的  发表于 13-8-17 14:38
疯子  尼龙大齿不奇怪,一样很好用的,而且还很安静  发表于 13-8-16 20:10
wangfei555 金牌 Fans 发消息
发表于 13-8-16 20:06:21 |显示全部楼层 来自: 中国北京
全黑也很好看!!!
发表于 13-8-16 20:09:56 |显示全部楼层 来自: 中国天津
铝合金前狗骨?敢不敢再蛋疼点?用个弹簧钢能重多少?铝合金的强度和耐磨程度…天…
kkwong  中央传动轴铝的话,一场报废。随便玩的另谈。 此车跟原来版本一样的啊,只是把一小部分OP件加上去而已,不过看图好像也没多多少。呵呵。。。  发表于 13-9-3 09:04
sanfen  原版弹簧钢的都是弯的,铝合金的粗很多还更轻,最关键是直的。。。  发表于 13-8-17 14:17
Schocolade  我也在用铝制cvd。磨损可以接受。传动上的偷轻效果更好。  发表于 13-8-17 10:10
法拉利599GTB  竞赛车辆无需考虑耐用度  发表于 13-8-16 20:25
joho  是鋁合金中狗骨,本來是OP,我一直在用,蛋不覺得痛呀。:-)  发表于 13-8-16 20:24
疯子  这位朋友真够激动的。。。说的必然是中传动  发表于 13-8-16 20:14
6926215 论坛元老 发消息
发表于 13-8-16 21:10:52 |显示全部楼层 来自: 中国上海
中差多了一个补强支撑 摆臂也变了 避震孔位多了
发表于 13-8-16 21:18:04 |显示全部楼层 来自: 中国四川成都
就看出铝中轴和新摆臂了。{:soso_e113:}
怎么一直不出EB48T呢
疯子 论坛元老 发消息
发表于 13-8-16 21:20:43 |显示全部楼层 来自: 中国广西南宁
长风大侠 发表于 13-8-16 21:18
就看出铝中轴和新摆臂了。
怎么一直不出EB48T呢
有的啊,有ET48啊
dumbreminder 元老 Fans 发消息
发表于 13-8-17 10:56:03 |显示全部楼层 来自: 中国上海
没玩过这么好的车。。。单看设计已经很无敌了
