发表于 18-10-24 18:26:11 |显示全部楼层
TRAXXAS技术视频第三十一期--如何给Traxxas车壳贴贴花
视频原创发布 BY TRAXXAS
翻译               BY TRAXXAS中国总代理电波模型
因涉及到模型专业术语,如若翻译有误,欢迎指正
以英文原档为准,请参考:
TRAXXAS –How to Apply RC Decals
When applying decals to an RC body, these techniques can help to make the job a little bit easier.
With the right tools and some attention to detail, you can get clean, professional looking results.
We will use a ProGraphix Rustler body, See the related video for information on painting a Prographix body.
Always let the paint fully dry and remove the outer film before applying the decals
For application of the decals, we will use a hobby knife, small rubber squeegee and a bond folder like this one.
A burnishing tool or similar object can also be used for smoothing out decals in tight spaces
We will also demonstrate a helpful technique, using a solution of water with a few drops soap and some paper towels.
After applying the decals, a heat gun or hair dryer can be useful in working out any bubbles or blemishes and give the decals a clean finish
Use caution and adult supervision when working with these tools.
You can find images of production bodies with decals for reference at Traxxas.com
Before starting, make sure the body is clean and free of any fingerprints
Use the knife to carefully remove the decal, avoid touching the back of the decal or the body where the decal will be placed.
You can cut out a small piece of backing paper and stick it to the back of the decal to help with positioning and placement.
Removing the backing paper and use the squeegee or burnishing tool to smooth out the decal.
With the decal in position, carefully stick it down at one end and work your way across.
The bone folder or burnishing tool can help to smooth out smaller decals
Especially when placing them on uneven surfaces.
Now let’s use our liquid solution.
This technique works well for larger decals like windows and helps to avoid air bubbles.
Spray just enough to cover the area where you will place the decal and put it in place.
The solution allows for the decal to move around some, which will help to get it in position.
Dab up the excess solution with a clean paper towel and use the squeegee to smooth out the decal
Removing any air bubbles and working out the remainder of the solution.
Dry off the body and continue placing your decals using these techniques
If you do get a bubble that can’t be smoothed out, try piercing it with the tip of a hobby knife to release the air.
This is where a heat gun can come in handy.
Avoid overheating the decals or body.
Use low heat in combination with the other tools to smooth out any blemishes and give the body a clean, finished look.
Do you have any tips on applying decals?
Let us know in the comments below and check out Traxxas.com for more RC tips and tricks
请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新!
如果您想了解更多关于我们品牌的资讯,
请咨询电波模型淘宝店旺旺客服:
http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE
微信扫一扫,可得知最新资讯!
或联系我们
QQ  :2713236907/270570161
手机:13790546054  王小姐
