Xray XB4 2WD 电动越野车
13-11-3 11:52| 发布者: rcfans| 查看: 7799| 评论: 11
Xray 将推出 XB4 2WD 中置马达(mid-motor)电动越野车。基于XB4 4WD车架研发,2WD新车有95%的零件和4WD通用。使用分体电池,车架的重量分布经过优化,适合在泥地、地毯和草地赛道行走。Xray引以为荣的Multi-Flex(可调扭动技术)也被用在XB4 2WD新车上,I.S.S. 悬挂、铝制大容量避震器、强壮的限滑差速、高下压力DMX车壳都出现在新车上。
点击这里->进入Xray品牌专区参与互动
特性
– CNC-machined Swiss 7075 T6 alu backbone
– Precision-engineered composite chassis plate
– Top deck comprised of graphite top deck and alu front brace connected via bushing
– Front, center, and rear drivetrain bulkheads keyed to composite frame
– Integrated 25° front pre-angle
– Well-designed layout for optimum weight distribution and balance
– Composite battery straps
– CNC-machined shock towers made from premium-grade 3.0mm thick graphite material
– Optional weight mounting positions
– ISS suspension holders
– Complete set of CNC-machined Swiss 7075 T6 alu eccentric bushings included
– Wheelbase adjustment for frontward/rearward weight balance adjustment, or wheelbase shortening/lengthening
– Anti-roll bars made of special spring steel, interchangeable between front & rear
– Shaft-driven 2WD drivetrain with 1:2.5 internal ratio
– Adjustable central slipper clutch
– CVDs made from Hudy Spring Steel
– CVD assembly features composite safety collars
– Lightweight aluminium 14mm wheel hex drive hubs
– Super-smooth, super-light maintenance-free composite gear differential is ideal in most types of tracks
– Super-lightweight diff outdrives
– Big-bore, membrane-less shock absorbers
– SLP aluminum shocks have been shortened by more than 7mm to provide maximum stability under all track conditions
– DMX high-performance, low-profile aerodynamic body
– Stylish, effective rear wing made from strong Lexan
    引用 蜡包 13-11-4 16:34
    我该怎么办: 4wd的前波箱也在上面,两边黑区区的两个洞,好吧....
    估计会出两个OP件,心情的铝合金帽,堵上那两个洞
    引用 我该怎么办 13-11-4 10:01
    引用 alexssj319 13-11-4 04:40
    我擦 坑爹啊!!!!!!!  xray这是在扇自己的脸?????
    引用 fppppp 13-11-4 02:36
    这个也太坑了
    引用 SpeedOfLight 13-11-3 18:33
    现在就流行这个布局,,分体电+金属地+中置。。teamc也有这样的。。
    引用 rave1010hk 13-11-3 18:10
    用4WD只拆了前波箱改成的2WD,去了2WD车的那份轻巧及瀟洒感觉!
    引用 baishun 13-11-3 16:31
    这个太坑了
    引用 richmond 13-11-3 13:42
    XRAY也越来越坑!
    引用 TIGER9901 13-11-3 12:59
    感觉好像拆了前传动。
    引用 f19811125 13-11-3 12:14
    哇塞~一车两用,没后置马达吗?~!
    引用 Jason.An 13-11-3 12:06
    4WD改2WD……
    查看全部评论(11)
