TLR 22-4 1/10 4wd buggy
13-10-9 12:17| 发布者: rcfans| 查看: 11695| 评论: 4
Team Losi Racing(TLR)推出22-4 4WD电动越野车,1/10竞赛级产品,在最近的IFMAR世界赛上已经亮相。使用一块2.5mm厚度7075 T6铝制底板,传动系统采用了独特的多皮带传动,但是较同厂老款的XX-4更易维护拆装。22-4新车减轻了整体重量,提高了车架扭动性,除了新组件,新车还加入了大量铝制升级零件,让车子更强壮,提高完赛率。
点击这里->进入地平线模型产品专区参与互动
http://www.horizonhobby.co.uk/autoonline/j29_tlr/j29_kits/j29-tlr03005/j29-twenty-two-4-action/j29-twenty-two-4-01.jpg
http://www.horizonhobby.co.uk/autoonline/j29_tlr/j29_kits/j29-tlr03005/j29-twenty-two-4-action/j29-twenty-two-4-02.jpg
http://www.horizonhobby.co.uk/autoonline/j29_tlr/j29_kits/j29-tlr03005/j29-twenty-two-4-action/j29-twenty-two-4-03.jpg
http://www.horizonhobby.co.uk/autoonline/j29_tlr/j29_kits/j29-tlr03005/j29-twenty-two-4-image/j29-twenty-two-4-07.jpg
http://www.horizonhobby.co.uk/autoonline/j29_tlr/j29_kits/j29-tlr03005/j29-twenty-two-4-image/j29-twenty-two-4-08.jpg
http://www.horizonhobby.co.uk/autoonline/j29_tlr/j29_kits/j29-tlr03005/j29-twenty-two-4-image/j29-twenty-two-4-09.jpg
http://www.horizonhobby.co.uk/autoonline/j29_tlr/j29_kits/j29-tlr03005/j29-twenty-two-4-image/j29-twenty-two-4-16.jpg
特性:
- 2.5mm thick Hard Anodized 7075 T-6 Aluminum Chassis
- Belt Drivetrain
- Centralized Forward Motor
- Gen II Hard Anodized 12mm Big Bore Emulsion Shocks
- Revised Slipper System
- Improved Differentials
- Universals
- Small Diameter Outdrives
- Ball Bearing Steering
- Full Ball Bearings
- Ti-CN (Titanium-CarbonNitride) Hinge Pins
- Included Aluminum Parts
- Adjustable Anti-squat
- Metric Hardware
- Integrated Battery Hold Down System
- Wheels Only
- Mid-Cab Body
- Compact Wing Mount
12下一页
    引用 SDavy 13-10-9 20:30
    这车是不是一定要用分体电吃啊~
    引用 shi995800 13-10-9 16:19
    维护起来比较麻烦
    引用 y38639697 13-10-9 13:37
    限划螺丝怎么露在车壳外面呀!!!
    引用 聪哥 13-10-9 12:36
    LOSI的东西是看着舒服!
