Tekin推出RSX竞赛级无刷电子变速器。支持2S至3S锂电,可安装散热风扇。支持有感和无感马达,RSX电子变速器自带内置可编程功能和高压BEC系统,支持6V至7.4V输出,180A,支持2.5T 2S和8.5T 3S动力配置,适合各类型1/10竞赛级遥控车使用。 Features: – Billet aluminum heatsink housing – Optional fan shroud system and high speed fan for maximum cooling – Ultra-smooth and precise throttle and braking control – Compatible with sensored/sensorless brushless and brushed motors – High voltage programmable BEC – EZ access HotWire programming port – HotWire PC interface for advanced programming and updating – On-board temperature indicator – Gold-plated solder posts for easy wire replacement Specifications: – High voltage BEC (6.0v/7.4v) – Controls: forward/brake/reverse – Input voltage: 4-9 cells, 2S-3S LiPo – BEC: 6.0v / 7.4v 5.5amps – Timing profiles: 7 choices (on board) – Dimensions: 25.4x33x12.9mm – Weight: 42g |
