Xray 2013 spec RX8 1/8油动平路车
13-4-26 20:48| 发布者: rcfans| 查看: 10323| 评论: 3
Features:
- All-new fuel tank with interior baffles for stable engine performance
- All-new Low Profile (LP) shocks
- All-new lower alu shock bodies
- All-new shorter shock rods
- All-new fixed Delrin pistons
- All-new Short Shock Springs (3S)
- All-new front and rear lowered shock towers
- All-new Reverse Clutch set for increased performance & durability
- All-new shape of clutchbell
- All-new clutchnut
- All-new ultra-stable clutch spring
- All-new redesigned front lower bumper for increased downforce, durability & stability of the car
- All-new redesigned front upper bumper for increased durability
- All-new redesigned rear lower arm 2-positions graphite shock holders for increased durability
- All-new independent muffler mounting
- All-new longer muffler wire
- All-new front left bulkhead
- All-new rear 2-speed shaft ball-bearing for increased durability
- All-new rear right bulkhead for larger 2-speed shaft bearing
- All-new stronger servo saver spring for increased steering and improved steering response
- All-new steel servo saver pivot shaft for increased durability
- All-new steel belt tensioner bushings for increased durability
- All-new steel brake cam post for increased durability
- All-new composite rear body holder for higher body mounting
- Included optional lightweight front middle shaft from HUDY Spring Steel
- Included optional lightweight alu brake disk adapter
12
    引用 GAMOlover2 13-4-28 23:11
    看起来很漂亮的样子o !
    引用 richmond 13-4-27 18:26
    想入手,但是没场地跑呀!
    引用 lxg 13-4-27 02:10
    好车。。。。。。。。。。。
