Reds Racing推出Team Edition 2越野车用竞赛级引擎,基于数位顶尖车手已经在使用的R5T研发而成。新版Team Edition 2能够减少油耗同时提高性能,散热效能也有提高,意味着引擎能够在更苛刻环境下运行。换上了新款曲轴等组件,散热顶重心也变得更低,使用了Reds独有的低阻力强化RDC黑色尾盖和陶瓷轴承。相信TE2是一款性能卓越的竞赛级产品。 Specifications Category: 1/8 off road Displacement [cm^3]: 3,5 Bore [mm]: 16,2 Stroke [mm]: 16,9 Inlet ports: 5 Outlet ports: 1 + 2 boosters Front ball bearing DixDexS [mm]: 7x19x6 Front ball bearing features: Swiss Made Rear ball bearing DixDexS [mm]: 14×25,4×6 Rear ball bearing features: Swiss Made Ceramic Carburetor diameter [mm]: 6,7 Carburetor setting: Long needle Glow plug: turbo 4,5,6 Weight: 348grams Cylinder system: ABC Exhaust type: rear Recommended pipe: EFRA 2069 / 2099 / 2104 Recommended fuel: 20-30% nitro, 11-12% oil Break-in fuel: 12% oil |
