Kyosho Ultima RB6 2wd电越
12-8-1 10:09| 发布者: rcfans| 查看: 6604| 评论: 4
Kyosho京商推出全新Ultima RB6两驱电动越野车。超过一年的测试时间,包括厂车手Jared Tebo在内的顶尖车手参与了新车的研发测试。7075铝制强化底板,两种马达位置设定,分别是尾置和中置(Rear 3 gear setup 和 Mid 4 gear setup),换句话说Losi不再是马达摆放位置可变的独家越野车制造商了。RB6能够使用分体电或直条电池,较RB5车架长了13mm的轴距,RB6新车的行走稳定性大大提升,整车低重心设计,无论是高速行走还是跳跃都有极佳表现。RB6的面世,必定会让竞赛级两驱电动越野车竞争变得更为激烈!2012年9月上市。
Features:
  • 7075 Machined hard anodized aluminum chassis with angled sides.
  • 2 motor layout setups included in kit - Rear 3 gear setup and Mid 4 gear setup.
  • Smart battery tray design Compatible with short, straight and saddle packs with both mid and rear motor setups.
  •  Long Wheelbase The chassis is now 13mm longer than the original RB5, giving you amazing stability.
  • Reversable rear gull-wing suspension arms allow for more agile turning and stability in bumpy terrain.
  • Velvet coated big bore shocks with new one piece alloy caps and X-Gear® springs.
  • X-Gear® diff lubricants
  • New high down-force "Blade" cab forward body
  • New Step 2.0 M rear wing
  • Super low CG design
  • New steering crank design.
  • All new front end geometry with adjustable caster blocks via inserts.
Technical Data:
  • Scale: 1/10
  • Length: 395mm (15.5in)
  • Width: 249mm (9.8in)
  • Height: 140mm (5.5in)
  • Wheelbase: 285mm (11.2in)
  • Gear Ration: 2.6:1 (1st)
  • Weight: 1,620g approx (w/body)
    引用 even107 12-8-2 00:50
    好简洁的设计!
    引用 cure 12-8-1 20:08
    Seem's look like Durango .......... @v@'''
    引用 yu43085251 12-8-1 11:40
    刚刚看到这个消息
    引用 crusaderlyf 12-8-1 10:31
    刚刚看到这个消息,更新得挺快,官网上面似乎还没有证实,不过kyosho是肯定的了,但是名称,预计也是叫rb6,其转向很新颖
