11-11-9 01:42| 发布者: admin| 查看: 7473| 评论: 4
Reedy推出全新540-SL 和 550-SL 无感无刷马达。其中540级马达非常适合1/10越野车和卡车使用,550级别适合现在非常流行的短途卡车使用。
Features:
Oversized precision ball bearingsHigh-strength 2-pole rotor (540-SL)High-torque 4-pole rotor (550-SL)Hardened 1/8″ steel shaft (540-SL)Hardened 5mm steel shaft (550-SL)Triple-insulated windingsSensorless operation3.5mm connectorsCompletely serviceable
Source : Reedy
评论
