Team Associated Factory Team RC8.2e电动越野车
11-10-26 13:45| 发布者: admin| 查看: 6471| 评论: 5
Team Associated(AE)正式推出全新的Factory Team(厂队版)RC8.2e 1/8电动越野车。加长3mm的7075强化底板的车架重心分布更合理,操控性能更好。新设计的悬挂摇臂,16mm大容量避震器让RC8.2e轻松通过各类型越野路面。JConcepts Punisher 车壳和 Illuzion定风翼也包括在产品内。相信这是一辆高性能1/8 电动无刷电动越野车!
RC8.2e Factory Team
Vehicle Specifications
Power Source: Electric
Terrain: Off-Road
Body Style: Buggy
Scale Size: 1:8 Scale
Assembly Level: Kit*
Length: 470mm (18.5in)
Width: 305mm (12.01in)
Wheelbase: 323mm (12.72in)
Weight: 3570g (7.87 lbs)
Internal
Gear Ratio:
4.30:1
Drive: 4WD
* This vehicle comes as a kit and must be fully assembled by the user. Electronics and/or an engine/motor may be required.
The RC8.2e Factory Team Kit Features:
Features
  • Factory Team blue aluminum sliding motor mount
  • Factory Team 3mm lengthened 7075 hard-anodized chassis
  • New suspension arms feature centerline shock mounts and optimized anti-roll bar position
  • Factory Team 16mm Big Bore hard-anodized threaded shocks with 4mm titanium-nitride coated shafts
  • Factory Team 5mm 7075 aluminum low-center-of-gravity shock towers with optimized geometry
  • Factory Team 7075 blue aluminum suspension mounts
  • Factory Team 7075 blue aluminum steering knuckles
  • Factory Team 7075 aluminum axles and center drives
  • Factory Team 7075 blue aluminum one-piece top plate
  • Factory Team lightweight ring gears
  • Factory Team lightweight diff outdrives
  • Factory Team aluminum steering posts
  • CVA boots on center and rear drive joints
  • New low-center-of-gravity wing mount
  • JConcepts Punisher Body and Illuzion wing included
  • Molded composite radio tray
  • Molded composite front and rear chassis braces
  • Tough steel-alloy shock standoffs
  • Factory Team 83mm "big" wheels included
  • Caster blocks adjust 14, 16, or 18 degrees with molded inserts
  • 3.5mm light CVA drivetrain with full ball bearings
  • Factory Team shock and differential fluids included
    引用 追风逐影 11-10-27 11:10
    好车,估计价格也好,呵呵。
    引用 y002943 11-10-27 07:56
    广州哪儿有卖?
    引用 terry_MT4 11-10-27 00:18
    就等它了!!!
    引用 tw8180 11-10-26 16:55
    这才是好车~~~舍弃e 811我就等你的
    引用 mikesue 11-10-26 14:17
    http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=391011&extra=page%3D1
    大家来讨论吧
    查看全部评论(5)
