Losi 5ive-T 4wd汽油短途卡车!
11-9-9 00:57| 发布者: admin| 查看: 10267| 评论: 19
没错,这是“汽油遥控车”!Losi推出1/5 四驱26cc汽油短途卡车,名为5ive-T 4wd Offroad racing truck!四驱传动系统基于获奖无数的8ight设计而成,Spektrum 2.4G DSM遥控设备、遥测系统(可探测引擎温度、接收机电压、车速等参数)、超大容量7mm轴心避震器、800cc油箱、大型舵机等都被装备在这台新车上!空气和燃油分别有过滤系统,确保引擎有清洁的空气和燃料提供运转。分为四件组成的车壳,损坏了任一部分,无需整个车壳更换,只需要单独更换损坏部分组件即可。汽油车世界又多了一辆新力军,相信Losi 5ive-T是一辆高性能、高配置产品!
Features
- 4-wheel-drive power train
- SR3300T telemetry receiver with 2.4GHz DSM technology
- Telemetry sensors installed (temp, receiver battery voltage, mph/rpm, km/h)
- 5mm aluminium chassis
- Design based on successful 8ight platform
- Powerful Losi 26cc 2-stroke gasoline engine
- 3 tunable sealed viscous differentials
- Large-bore shocks with 7mm shafts/threaded adjusters
- Multi-piece beadlock off-road wheels
- Aluminium dual-disk braking system
- Extra-large 800cc fuel tank with clunk
- 1/4-scale heavy-duty metal gear steering servo
- 1/4-scale heavy-duty throttle servo for superior braking authority
- 2-stage air and fuel filter systems
- Full roll cage modeled after full-scale trucks
- 4-piece body with ability to replace individual panels
Specifications
Length: 38 in (965.2 mm)
Width: 20.75 in (527 mm)
Wheelbase: 24 in (609.6 mm)
Height: 12.25 (311.1 mm)
Weight: 30+ lb
Chassis: T6 aluminium, 5 mm
Engine: Losi 26cc 2-cycle
Suspension: 4-wheel independent
Shock: Aluminium, threaded adjusters, 7mm shock shafts
Drivetrain: 4WD with three sealed viscous differentials
Wheel: Molded composite beadlock with industry-standard hex size
Tyre: Off-road all-terrain
Receiver: Spektrum™ SR3300T with built-in telemetry
Battery: 6V 3300mAh NiMH Receiver pack/global AC charger
Body: Four-panel pre-decorated
    引用 我想你 11-9-13 20:58
    这个车多少钱啊
    引用 风语战士 11-9-11 19:46
    喜欢,可惜买不起
    引用 赛车 11-9-11 00:25
    四驱动的车就是比两驱动的好玩啊
    引用 铁丝 11-9-10 12:45
    这车我喜欢
    引用 camseries 11-9-9 21:26
    1600塊美刀!
    引用 洋1洋 11-9-9 19:42
    这车米不能少了
    引用 zhenglanlin 11-9-9 18:03
    四驱的啊。不错,感觉比HPI好
    引用 BAJA爱车族 11-9-9 16:54
    4驱还是很不错的 可惜1:5没有什么赛道跑
    引用 lyr418 11-9-9 14:06
    咪咪啊,快赚多点吧,没咪不行啊!
    引用 自由大帝 11-9-9 12:02
    LOSI向来的作风,不鸣则已一鸣惊人~~~
    引用 luofei 11-9-9 10:41
    liyingxia: 我操 真帅气!!!!!出了必买!!!!
    这车出了得多少钱啊?太V5啦
    引用 liyingxia 11-9-9 10:25
    我操 真帅气!!!!!出了必买!!!!
    引用 chengning0516 11-9-9 09:57
    分体车壳是一个创新~
    引用 lx0836 11-9-9 09:22
    我的天!losi!~~~~~~~
    还想年底如5SC呢啊 为神马!~~~~
    引用 weiweizhang 11-9-9 08:24
    很拉风的噢。赞!
    引用 海峡的风 11-9-9 02:17
    大块头有大乐趣~~
    引用 vision 11-9-9 01:36
    4片車殼應是上螺絲, 800cc 油箱應該可玩很久吧
    引用 邦德座驾 11-9-9 01:29
    四片式车壳设计,看着不是用R扣固定的,拆装稍微麻烦,但胜在够仿真。
    引用 jokeba 11-9-9 01:23
    这这这这·······哎呦我ku~!
    查看全部评论(19)
