Picco P-SIX 6-port越野引擎
11-7-27 17:15| 发布者: admin| 查看: 3647| 评论: 3
Picco推出新款 P-SIX越野车(buggy)用引擎。这是一款6 port turbo引擎,2.3匹马力@ 32,000rpm,高性能之外价格也非常有竞争力!引擎的内部机件也非常适合长时间的比赛,调教也较容易。
P-SIX .21 BUGGY
Based on our high quality production standards the P-SIX engine represents the answer to drivers looking for a real goodSIX ported turbo performance engine at a competitive price. The P-SIX has quality internal parts for a long lasting engine. Driveability and fuel economy are optimized for the latest buggy chassis’. Internally designed with low timing so you can fully appreciate the torque as well as the top speed. Designed with 6 ports, the P-SIX offers easy-to-tune characteristics and strong low end power. The reduced weight of the crankcase and cylinder head is an important advantage for your car 's handling.
The P-SIX is supplied with a 14mm “turbo” crankshaft, “knife edged” aerodynamic connecting rod, hard chromed brass lapped liner with 6 ports to optimize RPM at low range, lightened piston CNC machined from high percentage silicone alloy billet, turbo combustion chamber insert, light weight cooling head, 14mm main bearing, front rubber sealed dust protected bearing and the latest special designed buggy composite slide carburettor with 7.0mm venturi insert
Highlights:
    • 6 PORTS hard chromed liner
    • CNC machined billet Piston
    • 14mm turbo crankshaft
    • Knife edged aerodynamic connecting rod
    • Turbo combustion chamber insert
    • 14mm main bearing
    • Super lightweight cooling head
    • Lightweight crankcase
    • Buggy composite slide carburetor
    • 7.0mm venturi insert
Technical data:
    • Displacement: 3,49cc
    • Bore: 16,26mm
    • Stroke: 16,80mm
    • Output: 2,3hp @ 32,000rpm
    • Weight: 345gr
    引用 nightkiss 11-7-28 13:36
    后盖貌似是塑料的。
    引用 aorixu 11-7-27 23:33
    多少钱那买去啊?
    引用 7598523qq 11-7-27 20:22
    沙发必须的~
