Axial Wraith RTR 4wd 攀爬车揭开神秘面纱
11-4-5 21:00| 发布者: admin| 查看: 11518| 评论: 34
True 4-wheel drive locked differentials are included for improved traction and an offset pumpkin provides more ground clearance and a better driveshaft angle. Additionally, the rear axle has been shaved of any unnecessary items and steering linkages that normally stick down have been removed for as much ground clearance as possible. The AR60 OCP-Axle™ is constructed from high strength composite material which has a low flex rate but is not as brittle as standard glass filled nylon. The AR60 OCP-Axle™ tubes are reinforced and beefed up with a boxed-in axle truss to distribute stress over a larger area. The combination of our axles and a true 4-link suspension gives you optimal performance for any terrain with the look of a real 1:1 vehicle.
SPECS
CHASSIS
Wheelbase: 343mm (13.5")
Width: 295.3mm (11.6")
Height: 228.6mm (9")
Ground Clearance: 76.2mm (3")
Weight: 249kg (5.5 lbs")
ELECTRONICS
Radio: 2.4GHz, 2 channel
Servos: AS-2 Servo, 130oz servo @6.0volt - Metal Gear
ESC: AE-2 Forward and Reverse ESC w/Drag Brake
Motor: 20T 540/550 size
Lighting: Simple LED controller: 4 white LED's, 2 red LED's.
REQUIRED ITEMS (NOT INCLUDED)
Battery: (1) 7.2v Stick Pack/2S LiPo Pack
Battery Charger
Transmitter Batteries: (8) AA size batteries
OPTIONAL EQUIPMENT
SUSPENSION
AX30092 Aluminum Competition 72-103mm Shock Set (2pcs)
AX30110 13mm Aluminum Preload Collar (2pcs)
AX30111 Aluminum Shock Cap (2pcs)
AX30120 Aluminum Shock Body 12x47.5mm (2pcs)
AX30438 10mm Machined Piston - 1.2 (4pcs)
DRIVETRAIN
AX30395 Heavy Duty Bevel Gear Set - 38T/13T
AX30401 Heavy Duty Bevel Gear Set - 36T/13T
AX30402 Heavy Duty Bevel Gear Set - 43T/13T
WHEELS
AX08061 VWS Beadlock Wheels (2.2)
AX08135 2.2 Rebel™ Wheels - 41mm Wide (Black) (2pcs)
ALUMINUM UPGRADES
AX30760 Aluminum Steering Knuckle (2pcs)
AX30762 Aluminum C-Hub Carrier (2pcs)
MISCELLANEOUS
AX24251 Night Vision System
详细介绍,请进入Axial官方网站
http://www.axialracing.com/ftp/wraith/index.html
 已同步至 admin的微博
12
    引用 我爱 11-4-10 14:33
    我也喜欢这车,必买!!!
    引用 ljh361072374 11-4-9 22:09
    我不要 我自己做一个
    引用 疯狂石头 11-4-9 15:26
    695$?!?!
    太恐怖了
    引用 tanakam24 11-4-9 14:44
    very rock 'n' roll
    引用 小神童 11-4-8 18:30
    神马时候才有卖!我。。。。。已经中。。。。。毒!!!!!
    引用 zaku 11-4-7 22:29
    不能遥控锁差速,锁差速貌似要拆车
    引用 xxhhggssw 11-4-7 08:22
    中国军车,呵呵
    引用 猪烧烤 11-4-6 22:39
    看着很给力,观望!
    引用 nshock 11-4-6 22:25
    此车净重249KG,慎入:
    引用 cvleon 11-4-6 17:39
    看看官网介绍:
    引用 cvleon 11-4-6 17:38
    看看官网介绍:
    引用 zhenglanlin 11-4-6 17:36
    SUMMIT的竞争对手。。。能跑能爬
    引用 dex8 11-4-6 16:19
    严重的中轴车轴效应不知道有没有改善
    引用 冷火58 11-4-6 13:02
    后面有半裸的,嘿嘿
    引用 冷火58 11-4-6 13:00
    没裸照,看不到结构
    引用 3411411 11-4-6 12:55
    就想要个能跑能爬又能操的
    引用 zhongguojinanzi 11-4-6 10:16
    必入!!!!!!!
    引用 cybertnt 11-4-6 08:55
    2000以内是不可能滴·
    引用 极品飞车18 11-4-6 08:36
    估计得3000多
    引用 vision 11-4-6 01:38
    傳動有點特別, 差速都在一邊, 就是2500左右.
    查看全部评论(34)
