Picco推出Torque Edo Modified平路车引擎
11-1-30 16:47| 发布者: admin| 查看: 3711| 评论: 1
Picco推出新款TORQUE Edo Modified油动1/8平路车引擎,turbo盘顶、7ports、14mm turbo机轴、14mm瑞士轴承、轻量化散热顶,马力达2.8p,属于高性能竞赛级发动机.
 14mm “turbo” silicone-filled crankshaft to improve fuel flow and reduce weight, super aligned “knife edged” aerodynamic connecting rod, “hand fine finishing” hard chromed brass lapped liner with tear-drop workings on the ports, lightened piston CNC machined from high percentage silicone alloy billet, large size finned turbo combustion chamber insert for a better temperature dissipation, ultra light weight cooling head, 14mm Swiss quality main bearing, hand modified rear back plate to improve fuel flow and a composite slide carburetor with 7.0mm, 8.0mm and 9.0mm venturi inserts.
Highlights
• 7 Ports + 2 by pass hard chromed liner
• Piston CNC machined from billet
• 14mm turbo shaft
• Knife edged aerodynamic connecting rod
• Separate large size finned turbo combustion chamber insert
• 14mm Swiss quality main bearing
• Super lightweight cooling head
• Composite slide carburetor
• 7.0mm, 8.0mm and 9.0mm venturi inserts
Technical datas
• Displacement: 3,49cc
• Bore: 16,26mm
• Stroke: 16,80mm
• Output: 2,8hp @ 37,000rpm
• Weight: 335gr
Source : novasy.net
    引用 小小的86 11-1-31 12:18
    什么能告诉我去哪买这 ...
