Tekin RS Pro系列电调
08-3-8 19:19| 发布者: jovi| 查看: 2394| 评论: 0
老牌RC电子厂商Tekin发布了新的RS无刷电调系列。RS选用工业中最优质的原件制造,具有可靠性及精准的控制及强大动力。RS可配合所有无刷马达。它的面板上有温度显示器,高密度铜FET板及快速的单件编程系统。 有RS及RS Pro 两款可以选择,后者没有最低T数限制。
Features:
- Easily Access All Programming, Anywhere, Anytime
- Drives Sensor/Sensorless Brushless and Brushed Motors
- On-Board Temperature Indicator
- PC Interface for Custom Programming
- HDAC: High Density Copper Fet Boards
- Sensor Plug for Precise Commutation with all Motors
- Solder Posts for Easy Wire Replacement
- Self Test Diagnostics and Factory Reset
- Adjustable Drag Brakes
- RS-232 Digital Communications Protocol
- Pit Tune Mode
- DGF2: Digital Glitch Filtering V2
- QuickTune™ One-Touch Programming
- One-Touch Radio Calibration
- LCD: Lightweight Chassis Design
