MIP Black Handle 工具套装
23-10-23 16:14| 发布者: rcfans| 查看: 2555| 评论: 9
美国MIP推出Black Handle Set(黑色把手)工具套装连工具包。全套的工具包括不同尺寸的螺丝刀、内六角、套筒以及推杆设定扳手,无论入门玩家还是资深车手这套工具均能满足需求。产品编号5215。
工具列表:
Hex Drivers
- #9000B - MIP .050-in Black Handle Hex Driver Wrench
- #9001B - MIP 1/16-in Black Handle Hex Driver Wrench
- #9002B - MIP 5/64-in Black Handle Nut Driver Wrench
- #9003B - MIP 3/32-in Black Handle Hex Driver Wrench
- #9004B - MIP 3/32-in Black Handle Ball End Hex Driver Wrench
- #9007B - MIP 1.5mm Black Handle Hex Driver Wrench
- #9008B - MIP 2.0mm Black Handle Hex Driver Wrench
- #9009B - MIP 2.5mm Black Handle Hex Driver Wrench
- #9010B - MIP 2.5mm Black Handle Ball End Hex Driver Wrench
- #9011B - MIP 3.0mm Black Handle Hex Driver Wrench
- #9012B - MIP 0.9mm Black Handle Hex Driver Wrench
- #9013B - MIP 1.3mm Black Handle Hex Driver Wrench
- #9040B - MIP 2.0mm Black Handle Ball End Hex Driver Wrench
- #9043B - MIP 3.0mm Black Handle Hex Driver Wrench
Nut Drivers
- #9701B - MIP 4.0mm Black Handle Nut Driver Wrench
- #9702B - MIP 5.0mm Black Handle Nut Driver Wrench
- #9703B - MIP 5.5mm Black Handle Nut Driver Wrench
- #9704B - MIP 7.0mm Black Handle Nut Driver Wrench
- #9705V - MIP "Slim Fit" Nut Driver Wrench, 8.0mm (For Vanquish SLW Hubs)
- #9706B - MIP 3/16-in Black Handle Nut Driver Wrench
- #9707B - MIP 1/4-in Black Handle Nut Driver Wrench
- #9709B - MIP 11/32-in Black Handle Nut Driver Wrench
Turnbuckles Wrenches
- #9715B - MIP 4.00mm Black Handle Turnbuckle Wrench
- #9720B - MIP 3.70mm Black Handle Turnbuckle Wrench
- #9725B - MIP 3.25mm Black Handle Turnbuckle Wrench
- #9850B - MIP 5.00mm Black Handle Turnbuckle Wrench
- #9855B - MIP 5.50mm Black Handle Turnbuckle Wrench
    引用 bo68674 23-10-28 23:56
    比起hudy 如何
    引用 快使用双截棍 23-10-25 20:53
    顶级工具只有hudy手臂用着舒服
    引用 我不能说 23-10-24 14:17
    公制英制合并大套装?
    引用 remote2wd 23-10-24 08:45
    没个几千块买不了{:Umm:}{:Umm:}
    引用 Monsterr 23-10-23 22:20
    心情大于实用
    引用 藤原"拓海 23-10-23 22:00
    查了下价格,3500+???
    引用 tw8180 23-10-23 21:23
    哪里能买到
    引用 twicejohn 23-10-23 17:39
    怎么买
    引用 Life。 23-10-23 17:29
    黑色比黄色好看
    查看全部评论(9)
