HB Racing D2 EVO 1/10 2WD电越
22-6-17 19:07| 发布者: rcfans| 查看: 3305| 评论: 8
HB Racing将推出新车,D2 EVO 1/10竞赛级2WD电动越野车(Buggy)。由设计师Torrance Deguzman负责开发,D2 Evo配备了原厂的CNC铝制升级件、碳纤组件以及合成尼龙材料,在HB 1/8和1/10车型已经采用的单壳体悬挂摇臂也作为标准配置。全车大量可调和可设定设计,让新车在不同赛道的适应力更强,使用不同类型轮胎甚至不同尺寸轮胎的战斗力得到了保障,能够在全球各地各种赛道和环境作赛,首批量产1000台,产品编号204240。
D2 EVO 特性
Aluminum front arm mounts with optional adjustable kickup
Monocoque suspension arms with carbon fiber inserts as pioneered by HB in 1/8 scale & 1/10 4WD
Gullwing suspension arm design front & rear
Aluminum caster blocks with caster adjustment bushings included
Adjustable Ackermann geometry via optional steering hub arms
Adjustable droop setting via droop screws similar to 1/8 scale buggies
Ball bearing supported steering bellcranks with aluminum steering rack
Flat plate aluminum chassis so optional materials like carbon fiber can be used depending on racing conditions Adjustable battery position with quick change O-ring retainers
Motor cooling fan mounts built into the side guards
Dual disc adjustable slipper clutch
Machined aluminum gearbox with 3-gear laydown configuration
Easy access differential (ball & gear diff available)
Aluminum rear hubs with inserts for various hinge pin heights
Fully adjustable camber link position using spacers
Both inboard and outboard camber mounts can be finely adjusted up & down as well as inward & outward Clamping aluminum wheel hex drives
Arm mount inserts for toe-in and anti-squat adjustment
来自设计师TORRANCE DEGUZMAN:
“The D2 Evo was designed for total adjustability. Out of all the RC car racing categories, the 1/10 scale off-roaders are the most difficult to design because they race on a wide range of track surfaces, a wide variety of tires and even different tire sizes. As shown in the list of features, the D2 Evo covers that range. We’ve also implemented design features from our other kits to enhance this car, like machined aluminum components for higher precision and durability, monocoque suspension arms which have been a staple of HB off-roaders for the past decade, and droop screws which are ubiquitous in 1/8 scale but should add a level of convenience for 1/10 2WD.”
    引用 鳄霸王 22-6-18 23:57
    在主页看小图还没点进来时候,一眼看成dt02.....{:沮丧:}
    引用 firedragon 22-6-18 13:53
    日本车神那台,貌似1500
    引用 初学者俊俊 22-6-18 07:16
    差点看成yokomo yz2
    引用 Pokka 22-6-17 23:41
    限量版…注定不是下场艹的车
    引用 VQS 22-6-17 22:06
    这个底盘漂亮了,材质结构都上层次
    引用 人间无常 22-6-17 19:36
    套个甲壳虫壳就漂亮了
    引用 夕子嗯 22-6-17 19:16
    这车架得4000出头吧
    引用 D44444444 22-6-17 19:15
    来了
    查看全部评论(8)
