包装 Tamiya Mercedes-Benz G 500
19-9-21 21:39| 发布者: rcfans| 查看: 5334| 评论: 7
全新的Tamiya G500 搭配 CC-02 (Cross Country 2)底盘新车预计在下周2019全日本模型展亮相,新车的包装也正式曝光。CC-02相信是Tamiya设计师希望将Tamiya的穿越驾驶底盘带入下一个新时代的产品。产品编号58675,长度455mm、宽度196mm、高度207mm、轴距267mm,配备TLU-01 LED灯组。详细参数如下:
• 1/10 scale R/C model assembly kit. Length: 455mm, width: 196mm, height: 207mm. Wheelbase: 267mm.
• TLU-01 LED Light Unit and LEDs included.
• G 500 body is recreated accurately in polycarbonate. Separately molded parts are included for the front grille, side mirrors and spare tire cover.
• Designed for a wide range of off-road terrain including rocky surfaces, the CC-02 chassis’ ladder frame is inspired by full-size vehicles and is the base for its superior durability.
• A 4WD setup employs the motor longitudinally behind the front axle, with separated gearbox and transfer case, and propeller shafts transmitting power to the differential gears to the front and rear.
• Twenty gear ratios between 11.09:1 and 29.28:1 are possible using separately sold pinion gears, for some serious fine-tuning!
• 4-link rigid suspension front and rear, with CVA oil dampers.
• Differential Gears: 3-bevel differential gears provide a smooth driving. They can also be locked (with reassembly) for driving on poor surfaces.
• Axle Housings: Housings enclose a central differential gear and axle shafts in a rigid setup that lets the chassis take on rough terrain with ease: if one wheel rises, the other is pushed downward to help the chassis gain traction.
• Gearbox: Power from the motor is routed via the realistic looking gearbox and transfer case, from its propeller shafts to the differential gears, and finally to the wheels.
• 4-Link Suspension: A rigid setup employs 4 plastic link arms on each axle housing and four oil dampers. This ergonomic design offers superior durability and the ground clearance.
• Includes: Tamiya TBLE-02S ESC (electronic speed control) Capable of running sensor brushless motors and brushed motors alike. (21.5 Turn BL motor limit) (23 Turn brushed motor limit.
• Required Items: 2-Channerl radio, steering servo, 7.2-7.4volt battery pack with compatible charger, and Tamiya PS paint.
    引用 四驱改 19-9-23 23:11
    再这么挤牙膏一样,我掀桌子了
    引用 zaporozhey 19-9-23 12:04
    壳子不错
    引用 周涛 19-9-22 08:39
    和cc01fj40互换一下车壳,完美
    引用 FW190A8 19-9-21 22:56
    车头有点短啊
    引用 pal 19-9-21 22:50
    还有灯组 ?估计1.3-1.4k
    引用 meng1521 19-9-21 22:18
    桥壳明显是仿造我国的国产全金属攀爬车桥
    引用 剑舞枫飞 19-9-21 22:08
    想看看论坛有谁首发
    查看全部评论(7)
