Tekin推出一套无刷系统,名为R1,厂方宣称该无刷系统无论从性能和重量都较市面上RC用无刷系统优胜!厂方参数: FEATURES: Easily Access All Programming, Anywhere, Anytime On-Board Temperature Indicator PC Interface for Custom Programming *Tekin HotWire Required HDAC: High Density Copper Fet Boards Solder Posts for Easy Wire Replacement Self Test Diagnostics and Factory Reset Adjustable Drag Brake Pit Tune Mode Digital Glitch Filtering QuickTune™ One-Touch Programming One-Touch Radio Calibration
PROGRAM FEATURES: Drag Brake (13 steps) Brake / Reverse Strength (13 steps) Current Limiter (none, 12 steps) Neutral Width (7 steps) Throttle Profiles (7 choices) Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay Voltage Cutoffs (none, 2S, 3S, Custom) Extensive Tuning via Tekin HotWire PC Interface (sold separately) |
